Migration of CCM5 to CCM6
Mar 25th, 2009
I already using CCM5 in my compnay now we recently purchsed CCM6 with diffrent Hardware. Now i want to migrate all the configuration of my CCM5 to CCM6. I backup my ccm5 with the help of SFTP tool and tried to restore in my CCM6 but always its giving me error like (Features not found) so please tell me how i procced it further ?
rob.huffman Wed, 03/25/2009 - 07:36
Hi Fahad,
The problem here is that you cannot do a "Backup" on one version (CUCM 5.x) and restore this onto a new version (CUCM 6.x) Your best bet here would be to do an "in-place" upgrade to 6.x on your current 5.x box to 6.x and the do the Backup/Restore process onto the new box :)
Hope this helps!
Rob
mightyking Wed, 03/25/2009 - 07:36
What exact version of CCM5 do you have and which version of CCM6 are you upgrading to? There is a specific version of CCM6 you need to have in order to be able to upgrade from CCM5X to CCM6X.
If the CCM5 version allows, I strongly recommand you to go directly to CCM7.X.
See the compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40074
MK
fahadqureshi Wed, 03/25/2009 - 10:08
for your response i am already using 5.1 and i want to migrate that to 6.1 .. 5.1 is running on different Hardware and 6.1 is on different. please help me out in this
Jaime Valencia Wed, 03/25/2009 - 10:35
options:
a) take backup, install 5.1 on new server, restore, upgrade to 6.1
b) upgrade old server to 6.1, take backup, install 6.1 on new server, restore
c) manually move all info
in any case you also need to reach licensing so they rehost the license
those are the only options you have.
java
if this helps, please rate
