3750 Qos - mls qos queue-set
Mar 25th, 2009
I have to configure below CLI to allocate % buffer to all queue and set thrreshold but i don't know what is number 1 & 2 CLI , does it have any purpose ? or i can use any number ?
3750G(config)#mls qos queue-set output ?
<1-2> queue-set id
REgards,
Chintan
Overall Rating: 5 (1 ratings)
Yudong Wu Wed, 03/25/2009 - 09:00
  • Gold, 750 points or more
You can configure two sets of Qos queue parameters. Queue-set 1 and 2 are just two different sets of Qos queue parameter. By default, port will use queue-set 1. You can change it by "queue-set #" command under the interface.
chintan-shah Wed, 03/25/2009 - 09:35
Thanks, you mean i can change buffer value using default queue-set for all queue and no need to use queue-set 2.
Which scenario require to use both queue-set ?
Yudong Wu Wed, 03/25/2009 - 09:47
sure you can.
For example, if you want some of the ports in switch use certain qos queue parameter and the others use a different one for some reasons.
ccardon Fri, 04/24/2009 - 03:02
Hej Chintan,
You could for example assign "queue-set 1" to all of your user port and "queue-set 2" to the backbone trunk port.
int f0/1
description USER
queue-set 1
int g0/1
description UPLINK TO BACKBONE
queue-set 2
chintan-shah Thu, 04/30/2009 - 23:11
Thanks for further clarification. I am going to use same way now.
