WLC 4402 and coverage hole error software version
Mar 25th, 2009
Can you tel me what RRM coverage hole error:
%RRM-3-RRM_LOGMSG: rrmLrad.c:2462 RRM LOG:
RRM Verify Coverage Hole returned L7_FAILURE
means and how it can be fixed.
Thank you in advanced
Alejandro Corte... Wed, 03/25/2009 - 08:57
The coverage hole alarm is sent by Lightweight Access Point Protocol (LWAPP) to the Cisco Wireless LAN Controller (WLC)if the clients on the access point (AP) are detected at low received-signal-strength-indication (RSSI) levels.
Hope this help.
Leo Laohoo Wed, 03/25/2009 - 15:42
You either play with the automatic Radio Resource Management, deploy additional APs to cover the "hole" or disable SNMP/logging traps.
marcin.waliczek Thu, 10/29/2009 - 17:15
I'm interested in with the answer too. I got millions of syslog entries such like this: Verify Coverage Hole returned L7_FAILURE
Ok I can turn of Coverage Hole detection or syslog but it makes no sense :)
Can i Just remuve this message from sending to syslog ?
dmuralis Fri, 10/30/2009 - 17:54
A bug was filed on the controller code 5.2 for this undocumented error, and is fixed in 6.0 I believe.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
