LMS 3.1 Corrupt Topology VTP Views
Mar 25th, 2009
After reboot we lost the Toplogy layout
This has happend severals times and only in large maps with more than 190 devices.
maps with few nodes are ok
I have restored all files with the restorbackup.pl command but the old Topology layout is lost.
I have also restored the XML files under CSCOpx\campus\etc\users\userxxx without success.
Any hint or is this a bug?
Jeroen Tebbens Fri, 03/27/2009 - 03:31
We experience this before but found that the update topology option in the menu works like a charm. You can find it Topology Services main window, select File > Upgrade View Layouts. Then select the views you like to upgrade (auto draw) and upgrade.
Cheers,
Jeroen Tebbens
sbrox Fri, 03/27/2009 - 07:23
I have done that but I only get "No available view to upgrade"
