Can't Save Running Config in 1760 Router
Answered Question
Mar 25th, 2009
%SYS-3-CONFIG_NO_PRIVATE: No space remaining to save private config
When I attempt to copy running-config to startup-config, I get the above error message. There is plenty of space in Flash. When I look up the message in the error message decoder, it says it is most likely a bug. I am wondering if there is a work around, short of switching IOS versions. Thanks!
Correct Answer by Edison Ortiz about 8 years 2 months ago
You have 2759 bits free, not much.
I recommend implementing service compress-config if you haven't done it already:
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_r1.html#wp1015010
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 03/25/2009 - 07:33
  • Hall of Fame,
    Founding Member
The configuration is stored in NVRAM, not Flash.
Please post the show file systems output.
__
Edison.
bbeal-spang Wed, 03/25/2009 - 07:45
Oops! Sorry, I got confused because someone had written a config to flash. Here are results of the show file system:
rslkvpn01#sh file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw archive:
- - opaque rw system:
29688 2759 nvram rw nvram:
- - opaque rw null:
- - network rw tftp:
- - opaque ro xmodem:
- - opaque ro ymodem:
* 33292284 10530048 flash rw flash:
- - opaque wo syslog:
- - network rw rcp:
- - network rw pram:
- - network rw ftp:
- - network rw http:
- - network rw scp:
- - network rw https:
- - opaque ro cns:
rslkvpn01#
a.alekseev Wed, 03/25/2009 - 07:47
  • Gold, 750 points or more
you can try
conf t
service compress config
bbeal-spang Wed, 03/25/2009 - 07:54
Thanks to both of you! When I realized the config really had gotten too big to save in NVRAM, I deleted some unused access-lists and was able to save the config.
