Ginger Dillon Fri, 03/27/2009 - 14:06
  • Blue, 1500 points or more
Hi -
If you are using the CLI, not RTMT, make sure you are typing the correct case. The command should be: utils service restart Cisco Tomcat
You can check the services status by typing utils service list.
Ginger
pankajb Fri, 03/27/2009 - 15:51
The error I am getting is after giving CLI command.
cheng.cathy Sun, 05/08/2011 - 20:50
Hi Pankajb,
Have you resolved this problem? I run into the same problem, Tomcat stopped working and couldn't restart the service from CLI
