CCM 6.1 load balancing or failover question
cowetacoit
Does anyone have some documentation on how to run a NIC team on the CCM 6.1? I believe the servers we have are linux based. My over all goal is to provide some sort of failover but if i can team them for load balancing, that would be great. I'm going to be running GLBP and i want redundant connections for CCM Subscriber and Publisher.
yes, NIC failover means there will be only 1 IP being used at any given time independently if NIC 1 or 2 is working
java
if this helps, please rate
java
Jaime Valencia
set network failover
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpappa.html#wp1051765
java
java
Nice. So does it use the 1 IP Address on the active NIC then if it loses connection to the switch, it will enable the second NIC and use the same IP?
java
java
I am wondering if this is the case with when connecting to a port channel from a Cisco 6500 Virtual Swwitch System (VSS).
I couldn't find any documentation regarding this.
