Success rate of 3/5
Mar 25th, 2009
every time I try to ping i get a success rate of 60 percent, has anyone came across this problem. My routes seem ok because i can see all my learned routes from routing protocols..
Giuseppe Larosa Wed, 03/25/2009 - 08:24
Hello Lawrence,
it looks like you have two paths in parallel but one link is not working
try to use extended ping and to specify the source address in this way you can test each link individually by using a source address = exit inteface
Hope to help
mailaglady2 Wed, 03/25/2009 - 13:21
Hi Giuseppe
I think the problem here is the encapsulation used, I used HDLC and encountered this problem but when I removed HDLC and used to ppp it's working fine, image 12.4(20)T Can somebody running the same image try to configure HDLC and provide feedback please..
regards, Mpho
