Warning message
VG248 - Transient Connection - What is causing this?
Mar 25th, 2009
Our VG248 indicates an error in the CallManaegr Application Event Viewer. All 48 ports are registered in Call Manager so not sure why this is occuring.
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 0
Device name [Optional].:
Device IP address.: <Publsher>
Device type. [Optional]: 255
Reason Code [Optional].: 6
App ID: Cisco CallManager
Cluster ID: CM-Cluster
Node ID: <Subscriber>
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as ...
Jaime Valencia Wed, 03/25/2009 - 10:55
  • Cisco Employee,
  • Hall of Fame,
    2011
that is related to port 0 from vG248, configure it on CUCM and errors will disappear.
java
if this helps, please rate
paulcian_2 Wed, 03/25/2009 - 11:07
What is required to make the port configured? I am not using the Voice Mail integration so all I have on that port is the Device Pool and Calling Search Space.
Thanks for the reply.
