unable to boot an image
Mar 25th, 2009
I'm getting the following error msg when booting.
No images in /
Error 15: File not found
So I'm trying to use tftp in rommon mode but I can not ping anything from either ASA -> laptop or the other direction. I'm not sure I have correct SET variables in rommon mode.
See attached for details on the error as well as the exact steps I have taken so far.
Bernie
Can anyone help?
Luis Melendrez Wed, 03/25/2009 - 16:16
Does your laptop have the right ip address assigned?? If you laptop is your tftp shouldn't you have to assign 10.10.1.2?
bmckean Wed, 03/25/2009 - 18:11
opps, that was a typo on the document I created. The laptop has the correct address which is 10.10.10.2
bmckean Mon, 03/30/2009 - 11:21
I made the following changes:
GATEWAY=10.10.10.2
IMAGE=asa804-23-k8.bin
I successfully tftp the image and booted the asa. I did a write mem and reload and it boots back to rommon mode.
So I then, erased disk0: and tried again with same results.
I then downloaded a different image from cisco.com and get the same results.
see the attachment…
bmckean Mon, 03/30/2009 - 11:32
show ru
ciscoasa# show running-config boo
ciscoasa# show running-config boot
ciscoasa# dir
Directory of disk0:/
1374 drw- 0 10:27:14 Mar 30 2009 crypto_archive
1368 drwx 0 10:27:01 Mar 30 2009 log
0 bytes total (0 bytes free)
ciscoasa# dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
disk0: Directory or file name
disk1: Directory or file name
flash: Directory or file name
system: Directory or file name
ciscoasa# dir disk0: fla
ciscoasa# dir flash:
ciscoasa# dir sys
ciscoasa# dir system:
Directory of system:/
1 ---- 0 00:00:00 Jan 01 1970 running-config
No space information available
bmckean Mon, 03/30/2009 - 12:12
I got it working.
After performing the rommon/tftp steps listed above, booted the image:
1. formatted flash again
2. configured the asa int and gateway
3. copy tftp: flash:
4. write mem
