ASA5505 displays 0 length in disk0
Mar 25th, 2009
Hello All I've upgraded the IOS on this device from 7 to 8 with ROMMON, had to erase disk0 do to so now flash shows absolutely no length with 2 items listed. 0 bytes total (0 bytes free)
Richard Burts Wed, 03/25/2009 - 10:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Norm
I have not been through the upgrade of code with ROMMON so do not have experience to guide you. But it would seem logical that at this point you should copy the image files back onto disk0. If you use the fsck command on disk0 and on flash does it report anything?
Rick
Richard Burts Wed, 03/25/2009 - 10:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Norm
Have you tried format disk0?
Rick
Richard Burts Wed, 03/25/2009 - 14:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Norm
I am glad that you got it resolved. Thanks for posting back and indicating that the format did help.
Rick
