CAD Login Screen
Mar 25th, 2009
Is there a way to blank out the CAD Login screen each time you start CAD? I know you can do it by modifying the agent.ini properties but I was looking/hoping for a server side change. Essentially I want the agents to have to enter their username/password each time they start CAD and not have the last agent's username populated. CAD 7.2
villarrealed Thu, 03/26/2009 - 09:23
  • Bronze, 100 points or more
I don't believe that there are any settings within CAD that will block the saving of the username and extension. But as you said, the login information is stored in the agent.ini or phonedev.ini, depending on the version. You could create an Agent Management Workflow which launches a BAT file to replace this agent.ini/phonedev.ini file on agent logout.
