Issues with calling certain International numbers.
Mar 25th, 2009
I have call manager sending the calls out via a 2811 router with 2 PRI's. This gateway is only used for outbound calls. Certain numbers when dialed translate to a local number for no reason and other international numbers do not go through.
I have included a SHOW CONFIG of the router.
arthurbecker Wed, 03/25/2009 - 14:31
The only thing that I can see being an issue is the following:
voice translation-rule 1
rule 1 /^011/ //
voice translation-profile Int
translate called 1
But, i have othr numbers taht are called with no issues.
Nicholas Matthews Wed, 03/25/2009 - 15:07
  • Red, 2250 points or more
Hi Arthur,
I'm not sure why you've made this dial peer so complex.
This is what you have now:
dial-peer voice 1 pots
translation-profile outgoing Int
preference 1
destination-pattern T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
port 0/1/0:23
forward-digits all
This will do the same thing:
preference 1
destination-pattern 011T
port 0/1/0:23
On a pots dial peer, all numbers explicitly matched will automatically be stripped. This means 011 will not be included in the digits sent.
If you do want them sent, you could either use:
forward-digits all
OR
prefix 011
OR
no digit-strip
I wouldn't use all of them.
hth,
nick
