Pix 515 add a new interface?
Answered Question
Mar 25th, 2009
I've just installed a new 100mb nic card, Part is "Cisco PIX-1FE and when the pix boots up, it seems to recognize it but says it's disabled.
Anyone know how to enable the new interface?
Cisco PIX Firewall
Cisco PIX Firewall Version 6.3(5)
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Additional 1 interface(s) is(are) disabled
Looks like I might need to buy the license for it? Is that correct?
Correct Answer by Jon Marshall about 7 years 10 months ago
Then you need unrestricted license or you could look at using 802.1q on one of your interfaces and have subinterfaces ie. note that maximum physical interfaces = 3 but maximum interfaces = 5.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 03/25/2009 - 15:18
Does the new card take the physical number of interfaces to 4 ?
If so then yes you need to get an unrestricted license.
Jon
Correct Answer
Jon Marshall Wed, 03/25/2009 - 15:34
Jon
