copy startup-config tftp
Mar 25th, 2009
Is there any way to disable the confirmation when you copy a file from the router to a tftp server? I need to disable it because I'm doing a web application that manages the routers through commands with rsh. Thanks!
Overall Rating: 3 (1 ratings)
dhananjoy chowdhury Thu, 03/26/2009 - 04:09
  • Silver, 250 points or more
if its a script, which is putting the command, then you can add like
suppose for "copy running to startup"
In the script line go like this
copy running startup
y
y
The two characters "y" will do the consirmation.
