IOS SSL VPN application issues
Mar 25th, 2009
I have setup WEBVPN with the SSL client on a Cisco 2811. The WebVPN gateway is via a loopback address on the router, so I NAT port 443 to this address as it enters the ADSL interface.
Everything works great apart from when I try to access an internal address on the router itself (such as the internal LAN 192.168.0.1).
If I try to telnet to this address I connect but then spurious characters appear and the session hangs. I also cannot access the CME web pages via this address.
I have tried disabling CEF to see if some weird internal issue is the problem but that did not fix it.
Anyone else experienced this?
Scott
s-kirk Sun, 03/29/2009 - 04:48
I have now changed to a static IP address with my provider.
I reconfigured the WebVpn gateway to be the WAN interface and allowed https on the same interface.
The SSL VPN is still working great apart from when I try to connect to interfaces directly connected to the router.
Telnet (to LAN IP address) connects but then spurious characters appear and the telnet session hangs.
I would really appreciate some help on this one!!
Farrukh Haroon Fri, 04/03/2009 - 22:55
  • Red, 2250 points or more
Can you post your SSL+ACL related configuration?
Farrukh
s-kirk Sat, 04/04/2009 - 02:02
Farrukh,
As requested please see related config below:
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_2 local
aaa authentication login sdm_vpn_xauth_ml_3 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
ip cef
crypto pki trustpoint TP-self-signed-569873274
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-569873274
revocation-check none
rsakeypair TP-self-signed-569873274
crypto pki certificate chain TP-self-signed-569873274
certificate self-signed 01
interface GigabitEthernet1/0
description $SWDMADDR:192.168.0.2$
ip address 10.0.0.1 255.255.255.0
no ip route-cache cef
interface GigabitEthernet1/0.1
encapsulation dot1Q 1 native
ip address 192.168.0.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip virtual-reassembly
no ip route-cache same-interface
interface GigabitEthernet1/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip helper-address 10.0.0.1
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
ip mtu 1452
ip nat outside
ip inspect SDM_LOW out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ip local pool TEST 192.168.20.200 192.168.20.240
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
access-list 101 remark WEBVPN
access-list 101 permit tcp any host 203.206.169.63 eq 443
access-list 101 deny ip any any log
route-map SDM_RMAP_1 permit 1
match ip address 102
webvpn gateway gateway_1
ip address 203.206.169.63 port 443
ssl trustpoint TP-self-signed-569873274
inservice
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn context Default_context
ssl authenticate verify all
no inservice
webvpn context visicom
secondary-color white
title-color #669999
text-color black
url-list "WEB"
heading "Welcome"
url-text "OWA" url-value "http://192.168.0.10/exchange"
policy group policy_1
url-list "WEB"
functions svc-enabled
svc address-pool "TEST"
svc keep-client-installed
svc rekey method new-tunnel
svc split include 192.168.0.0 255.255.255.0
svc split include 192.168.20.0 255.255.255.0
svc split include 10.10.10.0 255.255.255.0
default-group-policy policy_1
aaa authentication list sdm_vpn_xauth_ml_3
gateway gateway_1
inservice
