03-26-2009 12:09 AM
Hi Experts,
My syslog.log file size is getting too large (about 9GB) within a month. Is there a way for me to run any job for me to archive syslog.log and compress it in a smaller file size?
Thanks and Regards,
Yi Shyuan
Solved! Go to Solution.
03-26-2009 12:15 AM
Yes, you can configure logrot.pl to periodically rotate and archive the syslog.log file. Search the Common Services online help for "logrot" for more on how to configure and schedule it.
03-30-2009 09:53 AM
Your Collector.properties is till pointing to NMSROOT\log\syslog.log. If your active syslog message file is a different file, you need to update the SYSLOG_FILES property in Collector.properties, then restart SyslogCollector and SyslogAnalyzer.
03-26-2009 12:15 AM
03-26-2009 12:49 AM
Hi Joe,
How should i specify the backup directory in edit variables? What number should i be inputting?
Thanks & Regards
YS
03-26-2009 09:46 AM
The backup directory is wherever you want it to be. This is where archives will be stored, so it needs to have enough space to hold them all. The number of revision is again, left up to you. How many old revisions do you want?
03-26-2009 09:49 AM
Hi Joe,
Thanks for the reply. I get what you mean now. But is it possible for me to automate or schedule this job to be run?
Thanks & Regards,
YS
03-26-2009 02:42 PM
From the Common Services User Guide
Chapter 4 Configuring the Server
Administering Common Services
(pages 4-102 and 103), logrot works as follows:
Running Logrot Script
To run the Logrot Script enter:
⢠On Windows:
Enter NMSROOT\bin\perl NMSROOT\bin\logrot.pl
⢠On Solaris:
Run /opt/CSCOpx/bin/logrot.pl
You can schedule log rotation so that the utility works on a specified time and day.
Hope this helps. Please rate this post if it does.
- Marvin
03-26-2009 02:50 PM
If you have LMS 3.1, you can schedule logrot from the Log Rotation screen. Else, here are the instructions:
logrot is typically run from UNIX cron or Windows AT. However, before
automating logrot, you should verify it runs on-demand. For example, to
run logrot on UNIX:
and on Windows:
NMSROOT\bin\perl.exe NMSROOT\bin\logrot.pl
Once you've verified things work on-demand, you can setup cron on UNIX:
0 1 * * * /opt/CSCOpx/bin/logrot.pl 2>&1 | /usr/lib/sendmail root
or AT on Windows:
at 01:00 /every:M,T,W,Th,F,S,Su C:\progra~1\CSCOpx\bin\perl.exe C:\progra~1\CSCOpx\bin\logrot.pl
(This assumes CiscoWorks is installed in the default location on Windows.)
Those commands will run logrot every day at 1:00 AM. The UNIX cron line will
also send all output of the command to root via email.
logrot accepts some command-line flags as well. If you pass -v to logrot,
logrot will output verbose messages as it runs. The -s option tells logrot
to shutdown dmgtd before rotating the logs. This can be a safer way of
doing log rotations (see the BUGS section below). The -c option can be
specified at any time to re-run the configurator.
03-27-2009 07:49 PM
Hi Joe,
Just would like to check with you, how can I view the scheduled job status in LMS login page (GUI)? When logrot job is started to run, will the syslog service and daemon manager being shutdown automatically?
Or is there such a need to stop syslog service for every logrot job to be done? As I realized the syslog collector status will be reset each time I shut down the crmlog service.
A crmlog error 1067 also encountered recently. Any way to correct it?
Yi Shyuan
03-27-2009 07:59 PM
If you have schedule logrot to run using AT or cron, then there is no way to see its progress in LMS.
If you configure logrot to do an offline rotation (logrot.pl -s) then Daemon Manager will be shutdown. For some log files, it is necessary to do an offline rotation in order to properly rotate them.
I do not know what a 1067 error is. What other details did you get? When did you get this error? What were you doing?
03-27-2009 08:05 PM
Hi Joe,
I am running logrot for syslog.log, will offline rotation be necessary? How can I configure the scheduled logrot job to run offline rotation? How can I cancel logrot schedule job?
The error 1067 is encountered each time when I stop and start crmlog. Is stopping crmlog necessary when I am running logrot on syslog.log?
YS
03-27-2009 08:12 PM
No, restarting crmlog is not necessary. However, this error could point to some other process binding to udp/514.
Just run logrot.pl -s to run an offline rotation. Logrot will handle automatically restarting Daemon Manager.
To cancel an AT job, just run:
AT ID /delete
Where ID is the ID of the schedule AT job. To cancel a cron job, just remove the entry from the crontab file.
03-27-2009 08:20 PM
Hi Joe,
How would advise me for the error I encountered when I stop and start CWCS Syslog service as my syslog collector status is not reset and number of syslog messages are now read as NA and the up time is not reachable. Please refer to the screen shot attached for more info.
Thanks n Regards,
YS
03-27-2009 08:29 PM
These numbers have nothing to do with crmlog. These point to a problem with SyslogCollector and/or SyslogAnalyzer. Try:
pdterm SyslogCollector SyslogAnalyzer
pdexec SyslogCollector SyslogAnalyzer
03-27-2009 08:36 PM
Hi Joe,
What should I be expecting from running this two commands? I don't see any output after running them.
YS
03-27-2009 08:38 PM
You shouldn't. That just restarts those processes. Check your Syslog Collector Status.
