MPLS FRR
Answered Question
Mar 26th, 2009
Hello:
I use IOS code 7200 Software (C7200-SPSERVICESK9-M), Version 12.2(33)SRC3
at default MPLS FRR works fine
when I shutdown pos interface on primary path, FRR works fine, but after I bring back pos interface, I noticed tu1 still use backup path
until I shut and no shut tu1
anyone could shred a light?
thx,
~mike
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello Mike,
this is normal the best path is not used as soon as it is up again, but when the next optimization time is triggered.
you should use show mpls traffic-eng tunnels brief
to see this.
see
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_te_frr_node_prot_ps6922_TSD_Products_Configuration_Guide_Chapter.html#wp1382260
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/26/2009 - 03:23
  • Hall of Fame,
    Founding Member
Hello Mike,
to see this.
see
Hope to help
Giuseppe
Harold Ritter Thu, 03/26/2009 - 12:15
  • Cisco Employee,
James,
You can also do a "mpls traffic-eng reoptimize" If you want to force reoptimization to take place right away instead of waiting for the reoptimization timer to expire.
baradasabut Mon, 03/30/2009 - 11:15
Hi Ritter,
By any chance, is it possible to schedule re-optimize at random intervals ?
Harold Ritter Mon, 03/30/2009 - 18:07
  • Cisco Employee,
Barada,
It will happen after the re-optimize timer times out, which one hour (3600 seconds) by default.
holden.matthew Tue, 03/31/2009 - 19:36
could you not also solve your problem by using
mpls traffic-eng reoptimize events link-up
Harold Ritter Tue, 03/31/2009 - 19:47
  • Cisco Employee,
Matthew,
This would certainly work. It boils down to how quickly you want your path to be reoptimized vs. network stability.
vijaykumarArumugam Fri, 04/03/2009 - 11:59
Hi Mike,
Instead of dynamic path option, configure an explicit path with "192.168.3.1" as strict hop and try the scenario.
In this case, when pos interface on primary path goes down the traffic will be rerouted via backup tunnel and the primary path will be retried for every 30 seconds. When the interface is back up, primary path signaling will succeed and tunnel will no longer use the backup path.
When tunnel uses the backup tunnel, "show mpls traffic-eng fast database" will display it's status as "active".
With dynamic path option, the tunnel will calculate a path which will be same as the backup tunnel path and it'll look like it's using the backup tunnel. To use the best path you've to trigger reoptimization (manual/periodic/event-linkUp).
Vijay
