03-26-2009 01:59 AM - edited 03-15-2019 05:06 PM
I have installed FXS ports on a 2821 router. Since two days ago they have gone into off-hook status and remained that way. I'm not able to make any calls. Please i need your input to resolve this.
2R#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxs-ls up up off-hook idle y
0/1/1 -- fxs-ls up up off-hook idle y
0/1/2 -- fxs-ls up up off-hook idle y
0/1/3 -- fxs-ls up up off-hook idle y
82R#
03-26-2009 08:56 AM
Hi!
Did you try to reload the router and see if the problem is cleared? What happens if you manually do a shut/no shut on the ports? Also check the IOS version, sometimes an upgrade helps if the IOS is too old. Otherwise probably you'll need to replace the cards...
Teresa.
03-26-2009 09:58 AM
'show voice call summary' ?
