Self signed certificates
Mar 26th, 2009
Dudes,
Is it possible to use self signed certificates for IPSec VPN?, I do not want to use preshared keys and third party CA for authentication.
If yes how do we do that.
Many thanks,
Rajesh
rajeshk200_2 Thu, 03/26/2009 - 08:24
I have seen that, It involves third party CA servers, I do not want to inlvolve CA's like Microsoft, Verisign, etc,
Rajesh
Wel - you need to generate the CSR, then you need a cert auth to validate the CSR. You cannot do this without a CA - the other options are in Unix/Linux - they can also sign/generate CSR's.
The Cisco ASA will not generate and sign certs for people/devices other than itself.
HTH>
rajeshk200_2 Thu, 03/26/2009 - 09:49
Andrew,
My requirement is to establish VPN tunnel between two Cisco routers with self signed certicates, i.e wanted to replace pre-shared keys with the certificates signed by router itself.
Is that possible on cisco routers?
Rajesh
rajeshk200_2 Fri, 03/27/2009 - 10:02
it looks matching my requirement, let me try this config, keep you posted the outcome.
Thamks,
Rajesh
