ACE SSL Offloading question
deyster94
Level 5
Level 5
I am working on implementing an ACE 4710 for a client and they would like to have SSL offloading configured. My question is do I have to create a certificate request in the ACE and get a certificate from that; or can I use the certificate they are already using for their website? I read through the SSL configuration guide and it didn't mention anything either way on this.
Thanks.
Dan
ciscocsoc
Level 4
Level 4
Hi Dan,
You should be OK using the existing certificate and key and the other individual certificates that make the chain.
Cathy
Thanks. I will give this a try.
