03-26-2009 06:53 AM - edited 03-04-2019 04:06 AM
I am running ios 12.4(20)T and my problem is when i configured HDLC, my connectivity drops intermittently but when I use frame-relay or PPP it functions normally. Can somebody confirm this for me, has any of you encountered this problem OR running HDLC without problems?
Solved! Go to Solution.
03-27-2009 12:25 PM
It's strange that you have a clock-rate configured. Likely you have an errored circuit, post output of show interface serail 0/3/0
03-26-2009 09:32 AM
Cisco routers use a proprietary extension to the industry-standard HDLC frame. It's called cHDLC and it utilizes a "network protocol" field in the header to support several different higher layer protocols that HDLC will encapsulate.
If you're peering with a non-Cisco router and using HDLC encapsulation, you may have a problem.
If they are both Cisco, you should not, in which case you may post your interface and CSU/DSU configurations here for us to examine.
If they are both non-Cisco, make sure that they both use the same HDLC implementation.
Victor
03-27-2009 12:12 PM
there's not a lot of configs, and the other side they exactly the same with different ip's.
interface GigabitEthernet0/0
ip address 192.4.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Serial0/3/0
ip address 165.148.120.1 255.255.255.252
clock rate 2000000
03-27-2009 12:25 PM
03-27-2009 01:05 PM
The strange thing is I am not getting that problem no more, everything is working fine now. I have configured clock rate because i am using traffic generator and I find it more accurate with clock rate configured than bandwidth command.. Thanks for all the help.
03-27-2009 05:37 PM
When you connect two router back-to-back with serial interface, the DCE side always have clock-rate commands.
