"Auth type not supported by External DB" error for web-auth SSIDs
Mar 26th, 2009
  • Silver, 250 points or more
Hello
We're having a problem with web-authentication on our 4404/WisM controllers since we moved to software rev 5.x (currently running 5.1.151.0).
With software rev 4.x our web-auth SSIDs would send the authentication requests to a Cisco ACS4.0 which would then authenticate the users against MS Active directory.
Now (with rev 5.x) the same SSIDs cannot authenticate users against AD, the error in the ACS is:
Found the following Cisco Doc regarding the problem: Cisco Secure ACS and Windows AD EAP/802.1x port authentication fails with the Auth type not supported by External DB error message - Case Number K24308566. Done a packet capture on ACS to see authentications coming in and the ones that fail with above error are using CHAP - from the Cisco documentation, MS AD doesn't support CHAP.
Any ideas on how I can get the web-auth working again with software rev 5.x ?
Andy
andrewswanson Thu, 03/26/2009 - 07:23
my apologies - theres a setting under Controller - General for Web Radius Authentication. changed this from CHAP to PAP and its now working ok.
Trending Topics - Security & Network
