Collin Clark Thu, 03/26/2009 - 07:36
PIX(config)#hostname PIXOne
PIXOne(config)#domain-name mydomain.com
PIXOne(config)#ca generate rsa key 1024
PIXOne(config)#ssh time-out 60
PIXOne(config)#ssh 75.50.95.72 255.255.255.255 outside
PIXOne(config)#passwd your_secret_password
PIXOne(config)#exit
PIXOne#wr mem
The ssh 75.50.95.72 255.255.255.255 outside line should be changed to be the address you want to manage the ASA from. Limit this to as few addresses as possible.
Hope that helps.
mburguk1000 Thu, 03/26/2009 - 07:48
Thanks for your swift reply, is that method just using a password and no other means of authentication
Collin Clark Thu, 03/26/2009 - 07:50
Yes. You can configure other methods though (local, radius, tacacs, etc).
vikram_anumukonda Thu, 03/26/2009 - 07:53
Step 1.
domain-name name
Step 2.
crypto key generate rsa
Vikram
Step 3.
Enable SSH on an interface.
ssh x.x.x.x netmask outside
default username & password are pix/cisco
