Turn Off or Disable Voice Encapsulation in DFM
Joe Clarke Thu, 03/26/2009 - 10:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The best you can do in terms of bulk unmanagement are the bulk management scripts under NMSROOT/objects/smarts/utils. The instructions for these scripts can be found by launching DFM > Device Management > Device Details for any device.
Joe Clarke Thu, 03/26/2009 - 10:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't have a router with such interfaces, but if they are all named similarly, you could run the getStateIntPort script, then search through the resulting file for the voice pattern, setting those interfaces to unmanaged. Then run the setStateIntPort script to update DFM.
