Port Channel Physical Requirements
Mar 26th, 2009
I'm working on a MAN project. The client has 3560s at the remote location and 6500s at the Hubs. The Fiber runs in a ring from each individual location back to one of the hub sites. So, the 3560 may have an LX GBIC in one port and a ZX GBIC in the other, based on the distance from the hub site going east and west.
My question is; Can I port channel these two Gigabit ports and if I do, will I see errors based on the fistance difference?
Edison Ortiz Thu, 03/26/2009 - 08:25
  • Hall of Fame,
    Founding Member
You should be able to, as long as the port configuration is the same.
and if I do, will I see errors based on the distance difference?
No.
HTH,
__
Edison.
