Cisco 7960 Telephones with 7914 Expansion Module
Answered Question
Mar 26th, 2009
Can you turn off the ringer & only see the lights on the lines located on the expansion module 7914 for incoming calls without affecting the volume to the calls that come in on the lines located on the 7960?
Correct Answer by testeven about 8 years 1 month ago
Hi!
There is a way in ccm admin pages to turn off ringer for a selected line/phone.
You need to go to Device--->Phone page and select an ip phone. Then you need to go to the line/directory number config for this phone and under the line configuration there are 2 fileds regarding the ringer:
Ring Setting (Phone Idle) Ring Setting (Phone Active) and you can disable it.
For more info, please refer to:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b03dn.html
HTH, if it does please rate.
Have a nice day!
Teresa.
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Thu, 03/26/2009 - 09:03
  • Cisco Employee,
Hi!
Have a nice day!
Teresa.
NRGilmore Thu, 03/26/2009 - 09:16
Hi Teresa,
It worked. Thanks!!!
Have a great day.
Nicole
