FWSM maintenance partition version
Mar 26th, 2009
I am planning an upgrade on our cat 6500 and it's FWSM. How can I determine which maintenance partition version I am actually running on the FWSM?
Thanks in advance for your help.
robertson.michael Thu, 03/26/2009 - 12:53
  • Silver, 250 points or more
Hi Annie,
Unfortunately, you have to boot into the maintenance partition before you are able to determine the version number. Take a look at the following document, which describes the procedure for determining the maintenance partition version:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/upgrade/guide/fwsm31up.html#wp2094993
Hope that helps.
-Mike
anniet Thu, 03/26/2009 - 14:21
Thanks Mike, that's what I thought.
Annie
