Privileged GUI access in 3560 Switch
Mar 26th, 2009
Hi All,
I am installing Cisco 3560 Switch. I have enabled HTTP access to the switch using "ip http server". I am able to open the switch in GUI Mode also using the Username and Password
It is opening in Privilege Level 15. Thus i am able to change / configure the switch setting if i login to switch using this username and password.
But I want to have different userlevel privilege to login to the switch. For example username staff should view only the port parameter details and not allowed to configure/Change the switch speed setting.
Another privileged user admin should be allowed to do all the activity like monitoring / configure the switch
Hope this information is enough to guide me
Thanks in advance,
R.B.Kumar
andrew.butterworth Thu, 03/26/2009 - 09:53
  • Gold, 750 points or more
Not currently possible as HTTP access requires Level 15 privileges and this can't be changed. You could use Cisco ACS & TACACS+ and enable command authorization and then assign users to different groups which have certain commands enabled or disabled. I think that is your only option.
Andy
