Warning message
Route tracking using IP SLA objects
Mar 26th, 2009
I have few questions.
1) if i am sending 5 packets after every 1 minute, then Is the object failed if even a single packet loss and other 4 replied.
2) After how much time it changes the route after the object actually failed?
lamav Thu, 03/26/2009 - 12:27
  • Blue, 1500 points or more
I believe that is what the threshold command is for. It sets the number of failed SLA monitor events that can occur before the alternate route is taken.
t4tauseef33 Fri, 03/27/2009 - 08:30
Thanks.
if i am sending 10 packets, 9 were successully recieved and 1 failed. so will the track object will fail or no?
Any documentation for this will be a great help.
t4tauseef33 Mon, 03/30/2009 - 05:37
Thanks.
This document related to the routers but in my setup i have cisco ASA firewalls and these doesnot have the configuration like one present in the document. Although the document you have supplied is very good but didn't help me out in my scenario. Can you please help me out in respect to firewall.
rpfinneran Tue, 03/31/2009 - 04:10
  • Bronze, 100 points or more
Hey,
Sorry, I can't help you with ASA's, I have only Check Point experience.
Sorry,
Ryan
ivarnhagen Tue, 03/31/2009 - 05:05
Maybe this link will be helpful regarding route tracking on the ASA:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
I havent done this on ASA before, so I'm not sure how the packet loss is handled regarding the frequency/threshold/timeout. I can imagine the tracked object only failing if all the packets go misssing, but you should try it out in a lab to be 100% sure.
Hth
