CVDM on CSS11501 Hostname Mismatch
Mar 26th, 2009
"The Name of the site does not match the name on the certificate. Do you want to continue?"
My options are "Run" or "Cancel" If I select Run it just sits there. How does this get fixed? I need to access to the GUI for my customer to take servers in and out of the load balance config without them using CLI. Is there a way to re-generate the cert? Is this a CSS problem or IE problem? IE7 running on Win2K3 R2 SP2. Java 6 update 13
