03-26-2009 10:32 AM - edited 03-04-2019 04:06 AM
What if I make OSPF and EIGRP the same AD? Which one will be preferred? Will OSPF and EIGRP then compare metric?
Solved! Go to Solution.
03-26-2009 10:36 AM
The native AD will be chosen.
For instance, if you have an internal EIGRP route (AD 90) vs an AD modified OSPF route (AD 90), the EIGRP route will be chosen.
While if you had an AD modified internal EIGRP route (AD 110) vs an OSPF route (AD 110) the OSPF route will be chosen.
HTH,
__
Edison.
03-26-2009 11:25 AM
Edison,
Just one correction. In the second instance, eigrp will chosen too because its native distance is 90 vs 110 for ospf. The only way to get ospf to win is to change its AD to be lower than the one assigned to eigrp.
03-26-2009 10:36 AM
HTH,
__
Edison.
03-26-2009 11:25 AM
Edison,
03-26-2009 11:38 AM
Oh yeah, thanks :)
