Edison Ortiz Thu, 03/26/2009 - 12:20
  • Hall of Fame,
    Founding Member
write erase
then
delete flash:vlan.dat
(reboot).
__
Edison.
sivaprakasam81 Thu, 03/26/2009 - 12:29
Okay. I will do that and update the same. For reload, can i use 'reload' command from CLI or Is there any reset switch on the hardware switch to reboot the switch to factory default?
Thank you,
Edison Ortiz Thu, 03/26/2009 - 12:31
  • Hall of Fame,
    Founding Member
Yes.
sivaprakasam81 Thu, 03/26/2009 - 12:36
Thank you very much!Is there any pre-cuastion need to check before the reload to avoid boot failure or ROMmode.
Like, Boot image verification, path?
Edison Ortiz Thu, 03/26/2009 - 12:37
  • Hall of Fame,
    Founding Member
It's always wise to check you have a valid image in the flash before rebooting. I suggest rebooting before the 'write erase' procedure and make sure it works.
__
Edison.
Edison Ortiz Thu, 03/26/2009 - 12:50
  • Hall of Fame,
    Founding Member
dir /all
or
show flash:
__
Edison.
sanmigueelbeer Thu, 03/26/2009 - 14:41
Aside from Edison's comment, during the bootup sequence make sure you keep a close eye for any error messages.
When the bootup sequence has completed, you have the option to do the following:
Enter into enable mode and type "sh post". If the system is OK, it should respond with "Pass".
