how to prioritize the traffic
Mar 26th, 2009
Hi.
We're running a 3745 router on the edge and a 6506 on the core. We have 2 connections going from the switch to the router, and are not utilizing any dymamic routing. Is there a way for us to priotitize the traffic between the 2 devices for a specific connection?
thanks..
Edison Ortiz Thu, 03/26/2009 - 13:12
How are the 2 links being utilized at the moment?
Are both links sending/receiving traffic to/from the 6500?
If so, how are you forcing the route to go via both paths? (static routing) ?
You can potentially implement Policy Base Routing (PBR) in the 6500 to match traffic based on a set criteria and set the next hop to be one of the links. You will need to do the same in the 3745 for return traffic.
or
Are you talking about configuring priority queue on both links for egress traffic from the 6500?
__
Edison.
