03-26-2009 12:21 PM - edited 03-17-2019 09:41 PM
We have CUVA running with our CallManager Express and 7960 phones. It works very well for internal calls.
However, when I try to dial outbound calls to the PSTN, the call never completes. Quitting CUVA allows the calls to go through.
I should point out that I'm not expecting the video to work, just to not block the call.
What can I do to fix this issue?
03-28-2009 04:51 AM
Hi Matt
Please see this document for a long winded explanation:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080569b65.shtml
Basically add 'bearer-cap speech' to your voice-ports on the router.
Aaron
Please rate helpful posts!!
04-02-2009 06:56 AM
We have a E1 card and the IOS doesn't seem to support this command. Is there something else I should be doing?
04-02-2009 07:09 AM
In these case, the access to the PSTN is Using an E1, I think is nothing what we can change, but our Telephony provider use CISCO 2651MX for the last mile E1 Access, and they use H323, attaché is the C-2600 config, and the Debug.
The problem persists!
mpls ldp logging neighbor-changes
isdn switch-type primary-net5
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
signaling forward unconditional
h323
modem passthrough nse payload-type 103 codec g711alaw !
voice class codec 1
codec preference 1 g711alaw
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
controller E1 0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
translation-rule 101
Rule 0 any 3019000
interface Serial0/0:15
no ip address
no logging event link-status
isdn protocol-emulate network
isdn incoming-voice modem
isdn sending-complete
no isdn gtd
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip classless
radius-server authorization permit missing Service-Type call rsvp-sync !
voice-port 0/0:15
echo-cancel coverage 32
bearer-cap 3100Hz
mgcp profile default
Debug:
c-cpv-2651PRI-E1Verdmont#
Mar 28 10:44:20.966 PTY: ISDN Se0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0B5A
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '3019043'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '3009547'
Mar 28 10:44:20.986 PTY: ISDN Se0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8B5A
Mar 28 10:44:21.038 PTY: %SYS-2-LINKED: Bad enqueue of 838BFCE4 in queue 82D770A0 -Process= "VTSP", ipl= 6, pid= 125 -Traceback= 803CDC50 81034284 813F9D7C 813FA390 81420EDC 813CCD54 81CC0F78 81CC18B4 813A6DC8 813A6FF4 813A8274 813A74B0 81304A50 81CC0F78 81CC18B4 81300C30 Mar 28 10:44:21.042 PTY: ISDN Se0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8B5A
Cause i = 0x82C1 - Bearer capability not implemented Mar 28 10:44:21.054 PTY: ISDN Se0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0B5A Mar 28 10:44:21.058 PTY: ISDN Se0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8B5A
