CUCM 7 Service provider SIP
Answered Question
Mar 26th, 2009
We are integrating a CUCM 7 to a service provider SIP trunk for basically calling out but I can not find where to place the user/pass that the carrier ask for.
Do I have to use forcibly a Gateway? or is there a guide?
Correct Answer by Nicholas Matthews about 8 years 2 months ago
CUCM does not support registering numbers to a SIP provider.
You may want to look into CUBE for this feature.
-nick
Correct Answer by mattcalderon about 8 years 2 months ago
There is no entry for a username/pass configuration on the CUCM and will require the use of a IPtoIP gateway or CUBE as it's commonly known as.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
You would be entering your credentials under the sip-au configuration mode on the gateway.
Matt
Overall Rating: 4 (2 ratings)
Correct Answer
mattcalderon Thu, 03/26/2009 - 13:10
  • Silver, 250 points or more
Matt
Correct Answer
Nicholas Matthews Thu, 03/26/2009 - 13:48
  • Red, 2250 points or more
-nick
