ASA 7.0(8) and WAAS
Mar 26th, 2009
Hello
So far I know that WAAS sets TCP options, 0x21 if I'm not mistaken, and upon neighbor discovery it adds 2 billon to the sequence number of the traffic that is meant to be accelerated.
Since I'm running an early release I was trying to manually overcome the absence of the “inspect waas”. Is it possible? So far, this is what I've got:
class-map WAE-TCPopt
match access-list WAE-TCPopt
class-map inspection_default
match default-inspection-traffic
tcp-map WAE
tcp-options range 6 7 allow
tcp-options range 9 255 allow
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect tftp
inspect netbios
inspect mgcp
class WAE-TCPopt
set connection random-sequence-number disable
set connection advanced-options WAE
class VoIP
priority
As you can imagine, it's not yet working.
Is there an alternative to the inspect. I would really want to keep the current release for a number of reasons. Any advice?
Thanks a lot
Guido
murabi Wed, 04/01/2009 - 12:55
You may try using the following command:
set connection {conn-max | embryonic-conn-max} n random-seq# {enable | disable}
no set connection {conn-max | embryonic-conn-max} n random-seq# {enable | disable}
random-seq# - Enable or disable TCP sequence number randomization. Each TCP connection has two ISNs: one generated by the client and one generated by the server. The security appliance randomizes the ISN of the TCP SYN passing in both the inbound and outbound directions.
Randomizing the ISN of the protected host prevents an attacker from predecting the next ISN for a new connection and potentially hijacking the new session.
TCP initial sequence number randomization can be disabled if required. For example:
•If another in-line firewall is also randomizing the initial sequence numbers, there is no need for both firewalls to be performing this action, even though this action does not affect the traffic.
•If you use eBGP multi-hop through the security appliance, and the eBGP peers are using MD5. Randomization breaks the MD5 checksum.
•You use a WAAS device that requires the security appliance not to randomize the sequence numbers of connections.
