7301 router boot loop
Mar 26th, 2009
Hello
I have a Cisco 7301 and we are trying to get BGP going using a 4 byte ASN. However the IOS that was uploaded is not liked by the router.
The router keeps going into a boot loop a few times and then it goes into rommon mode. Trying confreg 0x142 or 2102 does not help.
A snippet from the boot output below:
Self decompressing the image :
################################################################################################################################################################################################################################################ [OK]
(mem checks cut out)
%ERROR: Invalid IOS image for this platform.
System Bootstrap, Version 12.3(4r)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Are there any suggestions how I can resuscitate this baby? Like erasing the IOS from rommon or even set a jumper on the motherboard to clear everything off and let it load a basic startup config?
wvw
Leo Laohoo Thu, 03/26/2009 - 18:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hope this will help you.
ROMmon Recovery Procedure for the Cisco 7200, 7300, 7400, 7500, RSP7000, Catalyst 5500 RSM, uBR7100, uBR7200, uBR10000, and 12000 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
How to Upgrade from ROMmon Using the Boot Image
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml
willemvwyk Fri, 03/27/2009 - 02:18
Hi Leo
Thanks for the assistance, but unfortunately it looks like the only way to fix this is to use a Cisco flash card with the IOS we want on it, in order for this baby to boot. She is as dead as a doornail :(
wvw
Yasir Ashfaque Fri, 03/27/2009 - 22:37
No you can do it via rommon via tftpdnld, have you read the above documents ??
