Security Patches for Publisher
Mar 26th, 2009
Hi Cisco Engineers,
I would like to know and hear from you about my recommendation in applying the security vulnerabilities on my ip telephony servers.
Please see my attachements about the vulnerabilities name and recommendation
from Microsoft
Also i would like to know if there is a cisco recommendation.
Please help and comment.
Thank you very much.
lester
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 03/26/2009 - 21:12
  • Cisco Employee,
  • Hall of Fame,
    2011
the only patches you can apply on a CCM server are the ones available at cisco.com, you can apply the latest SR for your OS version or upgrade to a higher version if available
any patch you download directly from microsoft and install on your server will turn your system into unsupported. many times it will break the server, if you're lucky an un-install might suffice to get everything right. worst case scenario is you'll have to rebuild your server/cluster.
java
if this helps, please rate
lesterccna Tue, 03/31/2009 - 20:55
Hi Cisco Engineers
Thanks for the infos, ive got the Cisco OS Version of my server, could you please tell me what are the Cisco OS patches that will compatible to current installed CCM 3.3(2)es53
Current Cisco OS Version
Publisher
OS Image = 2000.2.3
OS Upgrade = 2000.2.5
OS Service Release = 2000.2.5sr4
ICD
OS Image = 2000.2.1
IVR
OS Image = 2000.2.1
Anything should be considered such as CSA Agent, BARS version,hardware requirements? Im afraid when upgrading the OS patches will caused the incompatibity of the system version and will ruined the cluster.
Lester
