Compression on Css 11501
Mar 26th, 2009
Could anyone how can i manually add the file extension(Eg:-.jsp/.CSS/.psp) as this is not by default supported on the firmware version 8.10 or 8.20 release. Hence can anyone tell me to add it manually?
syntax:url "/*.JSP ---Is this way do i need add the extension?????
Anyhelp would be greatly appriciated.
nehakulsum Fri, 03/27/2009 - 02:31
Hi Giles,
Thanks for that info,. Sorry I Want the .jsf file to get compress so please let me knwo how to add this file type.
Thanks in advance.
Gilles Dufour Fri, 03/27/2009 - 04:49
Follow the config guide I sent you.
Send all traffic to the compress service.
Whatever we can compress, we will compress it.
The rest will be sent uncompressed.
No need to make a selection yourself based on file type.
This is done automatically in the background.
Also, avoid sending multiple time the same question to the Forum.
nehakulsum Fri, 03/27/2009 - 08:40
Hi Giles,
Thanks for the update. Can you please let me know if this will be resolved in the coming version??? As I need this .JSF compress it is very important for me. Hence please let me know if this will get include in the coming software version or do we need to invovle cisco DU on this??
Thanks in advance.
