RSPAN problem
Mar 27th, 2009
Dear all, current we have a very simple RSPAN problem:
The topology is as simple as:
SW1 --- SW2
The configuration is also very simple
SW1:
interface GigabitEthernet3/12
description TO SW2
logging event link-status
logging event bundle-status
logging event trunk-status
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0 2 4 6 7
priority-queue cos-map 1 3 5
rcv-queue cos-map 1 2 2
mls qos trust dscp
switchport
switchport trunk allowed vlan 1-802,804-4094
switchport mode trunk
interface GigabitEthernet5/1
switchport
switchport access vlan 812
channel-group 3 mode on
interface GigabitEthernet5/2
switchport
interface Port-channel3
switchport
(truncated)
monitor session 1 destination interface Fa0/30
monitor session 1 source remote vlan 921
SW2
interface FastEthernet0/30
description Spare IT point ER1 I/O 857 (Cubicle A6)
switchport access vlan 200
switchport mode access
ip access-group DHCP-GUARD in
no logging event link-status
service-policy input limit-ping
spanning-tree portfast
spanning-tree guard root
interface GigabitEthernet0/2
mls qos trust dscp
wrr-queue cos-map 2 0
wrr-queue cos-map 3 2 4 6 7
wrr-queue cos-map 4 3 5
priority-queue out
Link Po3 and Vlan 812 are both showing up and there are data pass through data and a sniffer is able to see those data when connected to SW2 F0/30
But when the following commands are entered:
int range g5/1 - 2
mls qos trust dscp
int po3
mls qos trust dscp
end
The data from Po3 suddenly disappeared from SW2 F0/30, and all the broadcast data from VLAN200 start to appear in that. Does anyone have any idea on this? Please advise, thanks.
stephenshaw Fri, 03/27/2009 - 06:05
two items to check ...
1. Don't see the trunk port for SW2 - is it allowing the VLANs you need? SW1 is, but no info shown for SW2.
2. "monitor session 1 source remote vlan 921" is configured on both SW1 and SW2. But what VLAN do you really want to monitor? That VLAN should be configured on one of the Switches and also allowed across the trunk. Ensure the VLANs in question are configured on both switches too.
As an example if VLAN 200 needs to be monitored you would configure "monitor session 1 source vlan 200" on one of the switches only. The other switch would remain with the configuration you have "monitor session 1 source remote vlan 921"
As long as the VLAN 200 is also on SW2, the RSPAN will be able to monitor all traffic for this VLAN.
xianglingzj Mon, 03/30/2009 - 01:49
Thanks, I made a mistake in SW1 configuration, the SW1 RSPAN configuration shall be:
monitor session 1 source interface Po3
monitor session 1 destination remote vlan 921
