Issue with authentication with RADIUS when using VPN
Mar 27th, 2009
Our customer has a problem with auhtentication against Radius vhen he is using VPN or SSL VPN. Authentication on SSH or TELNET via RADIUS is working fine . When I configure on VPN (and SSL VPN) authentication against the local database, everything is working fine and tunnel is established.
In attachement is running-config of customer's gateway and capture file of communication between RADIUS server and gateway (radius access request starting at 85th line).
I found in this file at AVP attributes that the gateway is sending ipsec profile name (in this case "VPN") instead of username.
