03-27-2009 04:29 AM - edited 03-15-2019 05:08 PM
Hi All,
I am trying to implement Interoperability between CUCM and Siemens HiPath 3800, I have enable Qsig and completed all the required configuration,
Detail's
1.Controller E1 up
2.Serial port up
3.ISDN status is Multiple-frame-established
My problem is, I am not able to dial any of the extention in Siemens and vice-versa,
The debug gives Cause i = 0x81E6 - Recovery on timer expiry
when try to reach from Siemens I am getting a Busy tone,
Kindly check the Running configuration attached and help in troubleshooting this issue,
04-03-2009 05:55 AM
Are you sure the QSIG version is the same on both side: on Cisco QSIGv1 is ECMA, and QSIGv2 is ISO.
Just in case, the CCO URLs for Cisco-Siemens HiPath QSIG configs:
QSIGv2: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/603504nt.pdf
QSIGv1: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/607736nt.pdf
cheers
jp
11-29-2011 01:03 PM
Hi ajkhader123
Could you solve this problem.
I am facing exactly the same problem.
Thank you in advance
11-29-2011 03:12 PM
Youssef,
You have 2 posts in which refer to other quite old postings
May be you should start a new post and explain your set up and the issues.
Include your configs etc
Alex
