Maximum call duration in dial-peer settings
Mar 27th, 2009
How I can set maximum duration to outgoing call? Can I do it?
mightyking Fri, 03/27/2009 - 06:51
Note this setting will apply to all calls and can not be set for a singl call. If you're using CCM go to:
CCMAdmin--> Service --> Service Parameter --> Cisco CallManager -->Advanced
Default: 720.
Unit: min.
Minimum: 0.
Maximum: 35791.
Unfortunately with CCME there's no easy solution. You need to develop a TCL script.
MK
sbraychuk Fri, 03/27/2009 - 06:55
Yeah, MK. I have understand it also.
Have you the example of TCL script?
g.doychev Thu, 11/11/2010 - 00:19
Hey, did you managed with this? Did you developed a TCL script? I also need this functionality (max call duration). What do you think, will Cisco integrate it in the future IOS releases?
