Giuseppe Larosa Fri, 03/27/2009 - 06:57
  • Hall of Fame,
    Founding Member
Hello Vinoth,
depending on the IOS version the statements are automatically numbered or not.
in old IOS version you need to do:
copy the ACL to a text editor
modify it adding the desired lines in the required order
change the ACL number to a free unused number in the same range
paste to the router the new ACL
change the command using the old ACL to make it to point to the new one
OR
remove all the commands invoking the ACL
do
no acl number
paste from editor new ACL version
reuse the ACL
Note:
named ACLs allow to specify the position of the statement
Hope to help
Giuseppe
Giuseppe Larosa Fri, 03/27/2009 - 07:19
  • Hall of Fame,
    Founding Member
Hello Vinoth,
after having copied the whole ACL to a text editor you can also edit a statement if you need it
the procedure is valid also for changes on existing lines
Hope to help
Giuseppe
Tshi M Fri, 03/27/2009 - 09:00
  • Silver, 250 points or more
here is an example:
Extended IP access list Clients_Lan
10 permit udp any any eq bootps (95831 matches)
20 permit udp any any eq bootpc (27315 matches)
30 permit tcp any host 10.64.200.227 eq 8080
40 permit ip any host 10.64.200.225
i am going to insert a line between 30 and 40 using:
35 permit tcp any host 10.64.200.211 eq 443
regards,
Tshi M Fri, 03/27/2009 - 09:03
let say say to you to modify line 40 in the acl below:
Extended IP access list Trader_Lan
you'd use for instance
40 permit tcp any host 10.64.200.225 eq 11220
glen.grant Fri, 03/27/2009 - 08:00
  • Purple, 4500 points or more
On any IOS above 12.2T you just do a show access-list and it will show the numbers in the ACL . Then to modify
ip access-list extended
permit .
