3825 upon first boot up rtr has n> prompt
MichaelGF
What does a n> prompt mean? and how do I get to the regular "router" prompt
15 Replies 15
Michael,
Please post the exact prompt you got.
F.e.
Router>
Router#
rommon>
Toshi
the exact prompt was
n>
the IOS is correct for my project, the register is 2102
the enable command asked for a password.
Now that makes me suspicious
And.....responding
Mike
a.alekseev
Level 7
Level 7
dir flash:
boot flash:c3800-...bin
the IOS is correct for my project c3825-adventerprisek9-mz.124-13d.bin , the register is 2102
And.....Thanks for responding
Mike
Mike,
Well, When you already added the enable password. The prompt is "n#". Right?
Please try this out. To get a rid of what I had in mind.
n#conf t
n(conf)#hostname Router
Toshi
Eugene Khabarov
Level 7
Level 7
maybe "hostname n" command was setup?
Eugene,
You made me smile. Yea! It can be that way!
5P!
Toshi
others in my team think so too. the enable mode asked me for a password.
That makes all of this very suspicious.
The routers (2 3800s) are back on their way to the whse. I'm just really, really curious
Mike
Mike,
Please try this out. To get rid of what I had in mind.
n#conf t
Toshi
Toshi, so i was right, isn't it?
Eugene,
Stay tuned, We shall see.
Toshi
the enable mode with the n> had a password
here's more…
two routers, both 3825's, 1st rtr came up with the “n>” prompt
I had the onsite tech cold boot the rtr 5 times
the rtr came up with the “do you want to..” the initial config question
I got to the router# prompt and configured the rtr
the second rtr came up with the “n>” also
after 4 cold boots the prompt remained the same n>
I stopped the upgrade…
If it was a pre-confg, hostname, etc…. how did the 1st router loose it's config?
The routers had to be re-booted several times before the config was erased? This one goes to the books! That defies everything in relations to RAMs. One is OK (possibly a factory defect) but two? Seriously. Something was done to both for them to loose their configs completely.
Think about it. If your own laptop was rebooted several times, do you suddenly find yourself loosing your OS?
YOu wrotein your initial message that config register is 2102, is it for both or 2nd one.
The router which has lost config can have config register 2142 where it ignores config.
