ANM Certificate
Mar 27th, 2009
I'm trying to install a certificate for server authentication on ANM 2.1 but I'm experiencing an error.
"Exception in thread "main" java.lang.NoClassDefFoundError: com/cisco/nm/dcm/cs/platform/system/CertificateManager"
Is it a script error or a java version problem?
Thanks in advance
Roman
j-block Thu, 04/02/2009 - 13:51
Did you ever get an answer to this? I've seen this error before as well and couldn't find a solution.
roman.skrczypek Fri, 04/03/2009 - 04:42
Hi John,
unfortunately I didn't get an answer. The problem still exists.
Roman
CARL HEMMINGSEN Wed, 06/17/2009 - 14:39
Just wondering if you resolved this problem?
I have exactly the same issue installing a Certificate onto my ANM Server running ANM 2.1(1)
If you didn't have any luck, I will raise a TAC Case.
roman.skrczypek Thu, 06/18/2009 - 11:25
Hi Carl,
we resolved this issue. A Cisco SE investigated the problem an he found an error in a script. There was a wrong hard encoded version number in it. But unfortunately I cannot find the name of the script at the moment.
Roman
CARL HEMMINGSEN Thu, 06/18/2009 - 13:18
Hi Roman,
Did you raise a TAC case for this? If so do you have the SR number for it? It might make it easier if I raise it with Cisco.
Carl
Gilles Dufour Fri, 06/19/2009 - 06:01
  • Cisco Employee,
CSCsz19949: anm-certificate fails with Java exception on certificate install
If you open a tac case, we can give you a script that will automatically correct this error.
The script to change is
/opt/CSCOime/bin/anm-certificate
G.
CARL HEMMINGSEN Tue, 06/23/2009 - 20:21
OK, got the answer.
We are running ANM version 2.1, and were advised to edit the script /opt/CSCOanm/bin/anm-certificate and change the line that reads
ANM_VERSION=2.0
to read
ANM_VERSION=2.1
That was it. Obviously would be a good idea to take a backup of the script before making changes.
