Callmanager 7.0.2 generating CSR question
Mar 27th, 2009
How can we specify informations related with the CSR we want to generate, ex:
organization ??
To we have to edit directly the CSR data ? or a special WEB page exist ?
robetrem Mon, 03/30/2009 - 03:37
1) can you change the common name (we want to hide the real server name) ?
2) Stupid question: can we generate the CSR from an other system (specifying Tomcat) and then import the certificate in CCM 7 ?
htluo Mon, 03/30/2009 - 06:19
Depends on the CUCM you're running, you may run "set web-security" command on CLI to change some information (such as organization, etc.)
1) You cannot generate an alias name in the CSR.
2) You cannot do that. Each CSR has a serial number. It has to match with the certificate.
