Two BR1310 on each side
Mar 27th, 2009
I'd like to install two BR1310 on each side to douple the speed. Is that possible? Do I need a router to handle that? Maybe a white paper to that topic exists?
Greetings,
Rouven
jeff.kish Fri, 03/27/2009 - 09:33
  • Silver, 250 points or more
Hi Rouven,
Bridges create a simple L2 link, so think of these two links as being nothing more than long Ethernet cables. When you plug the two "cables" into their switches, you'll create a network loop. So you have two options:
1. Allow Spanning-Tree to block the loop
2. Configure Etherchannel on the switches to bond the two links
Take a look here for some good Etherchannel documentation: https://www.cisco.com/en/US/tech/tk389/tk213/tsd_technology_support_protocol_home.html
I hope this helps.
Jeff
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
