Backup Exec config on UnityUM 4.2
Mar 27th, 2009
We are having problems getting the Backup Exec software configured correctly to backup our Unity UM for Exchange servers. Does anyone have recommendations on how to set this up for daily full backups to a network drive?
Aaron Harrison Sat, 03/28/2009 - 04:39
  • Community Spotlight Award,
    Member's Choice, May 2015
What problems are you having? backup failing to connect to the server ? Some files not backing up?
In general, your UM server (as it will be a member server in your corporate domain) shouldn't require anything specific beyond what's documented for it:
- Ensure you are using open file/Exchange/SQL agents appropriately
- If you have CSA installed and enabled, try disabling it. The standalone CSA may not have rules compatible with your backup software - if you disable it you should ensure you are running up to date AV and OS patches (which you should, of course be doing anyway :-)
Aaron
Please rate helpful posts...
